power break..loud noise?! help again :P
Old May 3, 2005 | 06:08 PM
LenT1's Avatar
Wow my car is just full of problems I guess...
I just power breaked my car (1 tire concrete 1 on grass) after about 1 second it started making a loud grinding type noise, dont know if its from my clutch or the rear end....(i have a m6 obviously) only the passenger tire spun (grass) and the drivers tire didn't even give me a roll...! Whats the problem?
Old May 3, 2005 | 06:13 PM
camaroz28_97's Avatar
Re: power break..loud noise?! help again :P
I really dont think its a good idea to do that to the 10 bolt you probably screwed up the posy. And wrong form you want the drivetrain form
84 monte SS's Avatar
You just successfully blew up your first 10 bolt, welcome to the club!
Nah in all seriousness sounds like you blew some spider gears in the carrier.
Old May 3, 2005 | 06:19 PM
guywithaZ's Avatar
Does it still drive...have a friend stand outside and listen...my guess rearend damage...
This is why.
Old May 3, 2005 | 06:33 PM
LenT1's Avatar
eww thats not good, i dunno i havn't drove it since but im about to now
Old May 3, 2005 | 06:41 PM
LenT1's Avatar
Just took her around the block, drives fine, no shaking, no noises, still breaks the tires loose......is there any way my throw out bearing our part of the clutch can make that noise when the pedal is not pressed in??
Old May 3, 2005 | 06:46 PM
guywithaZ's Avatar
yes the TOB can squeek or rattle...but it shouldn't be real real loud...
Old May 3, 2005 | 06:48 PM
96ta(nick)'s Avatar
Welcome to the club, I did the same thing, killed the posy doing a burnout at the track,I have some good advice.... 12 bolt!!!
Fatdog2
Feb 12, 2015 12:24 PM
warmeck
Feb 5, 2015 11:04 AM
squarehead
Nov 21, 2014 08:02 PM
XtremeLt1
Sep 13, 2002 08:50 PM
Omega9
Aug 2, 2002 12:33 AM
