Powdercoating Vs. Ceramic on Headers
Old Feb 27, 2004 | 01:36 PM
pennys58's Avatar
What is the difference? Is powdercoating a good alternative? What are the pros and cons? Thanks.
John
Old Feb 27, 2004 | 02:19 PM
Brandon94Z28's Avatar
I believe powder coating is just what you use on things that need something more durable than paint. Ceramic is used as a heat barrier, things like headers and such.
Brandon
Old Feb 27, 2004 | 02:20 PM
Red96Lt1's Avatar
I've never heard of power coating headders. I have seen just crappy black paint, that will eventually bake off. If you can afford it, get the ceramic coating, it will keep engine temps down and prolong the life of your headders.
Old Feb 27, 2004 | 02:39 PM
pennys58's Avatar
The guy that does the powdercoating, says that he uses a 1600* temp triple powdercoating and will keep the temp. of the headers down and under the hood temp. down as well. He said not only will it control temperature, it will keep the headers from coroding. What do ya'll think. It is $100 to get them powdercoated aluminum. Good or no good?
Old Feb 27, 2004 | 03:52 PM
jkipp84's Avatar
Sounds kind of strange, but what the hell. Does he do the inside of the headers as well? If not, it's a waste of $100.
Old Feb 27, 2004 | 04:27 PM
pennys58's Avatar
That's what I thought stunk. He said that he could powdercoat inside, however, he couldnt get into the bends in the pipes So, you think it's a waste then???
Old Feb 27, 2004 | 04:43 PM
jkipp84's Avatar
Honestly, I know this sounds like it may be a good deal.. nice and cheap, but I'd pass and wait till it can be done right.
carguy0119
Apr 11, 2016 11:11 PM
Fastbird93
Apr 9, 2016 07:01 PM
WildRidez
Mar 27, 2015 08:22 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
