potential problems
Old Feb 25, 2004 | 02:28 PM
Jeremy_30th's Avatar
potential problems
I recently found that one of my heads were leaking coolant into the engine. (small leak) is there any possibility that this could have damaged somthing else ? plugs , cats or any internal parts ? also i recently had to flip for 2 new o2 sensors i guessing that was from the coolant to huh? thanks...
there are better days to come
Old Feb 25, 2004 | 03:22 PM
OK I SEE NO ONE IS HELPING HERE SO HELP YOUR SELF.. SHUD BE OK WHEN HEAD IS REPLACED
Old Feb 25, 2004 | 04:24 PM
Robs97Z28's Avatar
you will have to check to make sure that deck isn't warped(block). if the block is warp then the new heads won't seal correctly and will leak again.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
ShwaZedder
Apr 20, 2015 02:31 PM
