post any tip for LT1 owners
Old Mar 1, 2003 | 05:29 PM
cals400ex's Avatar
i thought it would be nice to post random tips about maintenance or anything else with these lt1's. we can help other lt1 owners out. i will get it started:
clean fuel filters help fuel economy and permance
thread lock works great for sealing drain bolts on the rearend and tranny
don't rely on a jack to hold a car up in the air
Old Mar 1, 2003 | 07:40 PM
Evilfrog's Avatar
Dont race LS1s... kidding.
If your going to change your spark plugs. Put the car on stands and drop the exhaust. Your knuckles will thank you later.
Old Mar 1, 2003 | 08:25 PM
Fullagar's Avatar
When taking out a manual transmission, make sure the clutch fork has been pulled out, and start the actual removal by removing the transmission from the bell-housing, then remove the bell housing from the engine.
Fullagar
Old Mar 1, 2003 | 11:13 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
dont pressure wash your engine bay
dont get into a "window race"
dont use slicks
dont use snythetic trans fluid
dont buy from racenet or SLP
dont buy aftermarket MAF on a stock car
get a trans cooler
dont get your wrench stuck in your TB
dont use regular 87 octane
dont brag about build quality
Old Mar 1, 2003 | 11:33 PM
rpm4lalo's Avatar
Could you elaborate on this topic please?
When I changed the fluid for my T56, I replaced it with Mobil 1 synthetic fluid. What brand would you reccomend?
Old Mar 2, 2003 | 12:48 AM
97droptopZ's Avatar
If you got a convertible, DONT mess with the gaskets... it may leak a little but its better then getting your whole interior wet when you wash it. need to take mine to an upholstry shop soon cuz that happened to me today
Old Mar 2, 2003 | 01:08 AM
treyZ28's Avatar
i'm talking A4
i dont know anything about the t-56 except that i have one laying around that i dnt know what to do with
big paper weight?
a4 you should use fords fluid-
this coming from a GM engineer who blows up 4L60E's for a living
Old Mar 2, 2003 | 01:15 AM
FastZinTennessee's Avatar
Never underestimate the power of beer to persuade people to help you on any of your car projects
Old Mar 2, 2003 | 01:22 AM
simple's Avatar
the T56 uses a dexron fluid like the automatics, do not use standard gear oil
when working in your cars engine bay do as much as possible at one time to save yourself the hassle of having to get into the VERY tight working conditions more than once
Old Mar 2, 2003 | 01:49 AM
treyZ28's Avatar
and KFC
Old Mar 2, 2003 | 01:53 AM
AENIMA95z28's Avatar
Oops, whats wrong with this?
Old Mar 2, 2003 | 01:56 AM
Dont buy Discount/Advanced Auto parts brake pads and rotors. Well... unless you like your brakes to sing !
Old Mar 2, 2003 | 02:03 AM
treyZ28's Avatar
was this a joke?
if not- the optispark will die
Old Mar 2, 2003 | 02:14 AM
kindaslo's Avatar
After the 4000 th time you have busted your knuckles cause you are working on one fo chevys biggest motors that they have put in on of their smallest spaces.....take a deep breath and throw more tools...
Old Mar 2, 2003 | 02:15 AM
treyZ28's Avatar
knuckle guards should have come standard with all headers
