Possible vacc leak around pcv...
Old Dec 13, 2003 | 02:13 PM
Myxtreme1's Avatar
Ok, I was doing the SEAFOAM treatment through the pcv valve. When I stuck it back on the intake I decided to check it for leaks. I poured a little seafoam on the hose and plug area and it started making a loud sucking sound! Could this be causing any other problems? What should I do? Thanks!!
Old Dec 13, 2003 | 03:02 PM
Maybe you need a new grommet or PCV valve. Some non-ACDelco replacement PCV valves have been known to be smaller in diameter and not fit snugly in the grommet.
Old Dec 13, 2003 | 08:44 PM
Myxtreme1's Avatar
Thanks, I'll replace both next week.
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
