Possible to use coil for tach signal?
Old May 18, 2004 | 10:36 PM
Gripenfelter's Avatar
Will using the signal wire off a coil for your tach cause a problem?
Which wire would you use? The one on the ignition module? White one?
Old May 18, 2004 | 11:33 PM
david97gsxr's Avatar
i'm in the process of installing nitrous on my car, and for the window switch i used the green wire going to the coil.
i havn't used it yet, but from the research i've done it looks like that's the one to use. if it will work for a window switch it should work for a tach.
someone please correct me if i'm wrong.
Old May 18, 2004 | 11:50 PM
Does a 1993 have white/black wire going from the ICM to the coil? If so, you can use it.
david97gsxr: that dark green wire is virtually the same one I am telling Grip to use. 96-97s have a little different wiring and a different coil.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
Aaront810
Sep 11, 2015 11:24 AM
Pwilson59
Sep 3, 2015 08:47 PM
