Is it possible to switch the connectors for the speed sensor and reverse lockout?
Old Mar 22, 2004 | 08:45 AM
ShelbyZ28's Avatar
Question Is it possible to switch the connectors for the speed sensor and reverse lockout?
Here is the situation...speedo doesn't work and I've noticed the reverse lockout seems to be messed up as well. Is it a possiblity that the connectors for the reverse lockout and the speed sensor were switched? It would make sense why both things won't work but is it even possible? Do they have the same connector style etc? I'm just trying to find every possible solution before I have to spend money for someone else to find the problem. Thanks in advance.
Bryan
Old Mar 22, 2004 | 08:50 AM
You can look at the wire colors to determine.
VSS-purple and yellow wires
Reverse lock out-brown and lt green wires
Old Mar 22, 2004 | 08:58 AM
ShelbyZ28's Avatar
Thanks shoebox. You seem to have an answer for every question . Hopefully this is the problem.
Bryan
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
jj_burchiel
Mar 21, 2015 12:51 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
Jul 4, 2005 05:00 PM
