Is it possible to switch the connectors for the speed sensor and reverse lockout?
Here is the situation...speedo doesn't work and I've noticed the reverse lockout seems to be messed up as well. Is it a possiblity that the connectors for the reverse lockout and the speed sensor were switched? It would make sense why both things won't work but is it even possible? Do they have the same connector style etc? I'm just trying to find every possible solution before I have to spend money for someone else to find the problem. Thanks in advance.
Bryan
Bryan
Originally posted by shoebox
You can look at the wire colors to determine.
VSS-purple and yellow wires
Reverse lock out-brown and lt green wires
. Hopefully this is the problem.Bryan
jj_burchiel
Mar 21, 2015 12:51 AM
Jul 4, 2005 05:00 PM
