Possible to OVERHEAT your car and NOT have DAMAGE?
Old Sep 13, 2005 | 02:07 AM
Black1995Z's Avatar
Question Possible to OVERHEAT your car and NOT have DAMAGE? *UPDATE*
Help! Look at my car! This morning it had a rough start but ran really well twice and on the third start up this happend!!
http://members.***.net/duperre/100_2123.MOV
Whats going on?!?!
__________________________________
I overheated my car while flushing the radiator tonight. I kept an eye on the dash but it was reading incorrectly for sure.. I noticed a little bit of steam from the radiator and then the car shut by itself off quietly. No knocks or anything. I havent touched it since. I'm waiting til tomorrow to turn it on to be sure its cold.
Question is-- Does something always go bad? Head gasket? warped head? Worse?
Is it possible to be completely unharmed? The car was idling and I didnt rev it at all.
Old Sep 13, 2005 | 03:09 AM
1racerdude's Avatar
Re: Possible to OVERHEAT your car and NOT have DAMAGE?
Ya probably didn't hurt it.Just make sure it has all the air out by bleeding it and keep it full of water.
Old Sep 13, 2005 | 03:47 AM
Honda Hunter's Avatar
My $.02 I blew a headgasket running it to hot but my gauge broke. I knew something was up after it overheated becasuse when it cooled down I tried to fill it up and while it would be running it was shooting all the water back out.
Old Sep 13, 2005 | 06:43 AM
Bawls's Avatar
i drove from Indy to Tennesse and back at around 240*. The reason I did was because I had thought that it was just a faulty sensor since the fans never kicked on, and the engine ran fine. Come to find out the radiator was clogged and I really was running at 240*. No damage though.
Old Sep 13, 2005 | 11:50 AM
Ryan 97 Ram Air T/A's Avatar
You're probably all right. If any damage was done its already going to need repairs so you might as well fill/bleed it and start it up again. If you think you have a problem then start with a compression check.
Old Sep 13, 2005 | 02:03 PM
Black1995Z's Avatar
Help! Whats happening! I ran really well this morning and then I started it up later and this happend!!!
Would spilling water/coolant on the opti do this?
USAirman93
Nov 24, 2014 03:37 PM
stanghunter211
Aug 29, 2002 03:04 AM
x7x7
Aug 15, 2002 06:49 PM
Mad_Ice
Jul 29, 2002 09:44 PM
