possible opti failure not sure though
Old Mar 27, 2005 | 12:05 AM
FryedClutch's Avatar
i was having a bit of trouble with my car runnin hot after the new motor install so i checked to makesurwe the coolant sys was bleed
sure enough it wasnt so i started bleeding it again and wasnt exactly uber careful so i get in the car to start it up and and it fires but i let off the ignition to early and then died so i go to start it again and then there was no go i thought i had flooded it so i took out the injector fuses and cranked it for a bit charged up the battery (just to make sure) snd still no start. i know it was getting fuel and the fuel pressure was around 42 i even opened the gas cap to let the pressure out and then tried it again and still had good pressure
im assuming i got water in the opti and killed it but any other opions would be appreciated
thanks
sean
Old Mar 27, 2005 | 12:22 AM
ManicHaze's Avatar
Re: possible opti failure not sure though
that would be my guess also. I did the same thing installing my 160 thermostat. Doesnt take much. I hit it with some contact cleaner and let it dry out over night and it fired fine in the morning.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
