Possible to install cam bearings without the tool?
Old Feb 29, 2008 | 05:09 PM
  #16
97 WS6 T/A Conv's Avatar
Originally Posted by mdacton
no
I would call the machin shop, tell them you will pay cash and help move the block etc. It will only take a few min. they need to be perfectly straight. If you have never done them you need someone else to do it.
I can put them in in a few min....take your cam with you and oil it up stick it in and make sure it turns nice and free before you leave.
Actually Eric Bradby has a trick he uses to install the cam bearings that's very similar to the threaded rod system we use to install the crank hub. It's been a few years since I saw him do it but he made it look easy.
Old Feb 29, 2008 | 05:14 PM
  #17
mdacton's Avatar
thats only for roller bearings you use that.
He uses the reg. tool for chevrolets......most all his fords get roller bearings, they are pretty cool, but expensive
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
