Possible to install cam bearings without the tool?
Old Feb 28, 2008 | 06:11 PM
Z28LT1_Just_Nasty's Avatar
Is it possible to remove and install cam bearings without the special cam bearing installation/removal tool? This is with the block completely disassembled. I can't justify buying the tool if I'm only going to use it once (its pretty much the only tool I don't have)
Local machine shop is backed up and I'm on bit of a tight schedule to get the car done before my vacation is up otherwise I'd take it to them. So if anyone has any ideas I'd like to hear them.
Old Feb 28, 2008 | 06:15 PM
mdacton's Avatar
no
I would call the machin shop, tell them you will pay cash and help move the block etc. It will only take a few min. they need to be perfectly straight. If you have never done them you need someone else to do it.
I can put them in in a few min....take your cam with you and oil it up stick it in and make sure it turns nice and free before you leave.
Old Feb 28, 2008 | 06:25 PM
marshall93z's Avatar
+1
Old Feb 28, 2008 | 06:54 PM
You might be able to do the two outside bearings, but not the inside ones. The tool makes it pretty easy. If it was the 'only tool I didn't have', I would buy one.
Old Feb 28, 2008 | 07:09 PM
96capricemgr's Avatar
I did a front one without the tool on a weekend in a big bind. Even that one was a hassle.
The tool is a lot cheaper than the consequences of getting it wrong.
Old Feb 28, 2008 | 09:38 PM
It's pretty easy if you have the tool. I did mine and had never done it before. Didn't take long at all.
Old Feb 29, 2008 | 03:58 AM
SS RRR's Avatar
I tried this on the front bearing of a friend's car with a flat piece of plastic by banging around the circumference in a circle and could never get one in straight. I haz no skillz!
Old Feb 29, 2008 | 04:59 AM
CANTONRACER's Avatar
My machine shop charged me $10 to put in the bearings....and the cost of the bearings.
I let them do it and I even have the tool and have done it dozens of times.
Old Feb 29, 2008 | 12:02 PM
$10 is cheap!
Old Feb 29, 2008 | 12:05 PM
mdacton's Avatar
Originally Posted by marshall93z
$10 is cheap!
I think most places charge around $35-$45 + the bearing price
Old Feb 29, 2008 | 02:04 PM
Geoffmj's Avatar
Sorry I dont meen to hijack the thread but since we're on the subject of cam bearings I was wondering if it is possible to remove and install cam bearings with the crank still in the block?
Old Feb 29, 2008 | 03:01 PM
I paid $30. Ended up doing them again myself.
Old Feb 29, 2008 | 03:03 PM
Ya I figure I might as well just buy the tool. I know more than likely someday I'll use it again or at least sell it. Thanks for the replies.
Old Feb 29, 2008 | 03:09 PM
mdacton's Avatar
never tried it...but its not that hard to go ahead and take it out....
Trying to cut corners always ends the same way
Old Feb 29, 2008 | 03:17 PM
The crank should not interfere, but the engine has to be out of the car.
