Is is possible to get crank hub off w/out air tools??
Old Apr 1, 2004 | 05:08 PM
BLUETOPTA's Avatar
yea, Is is possible to get the crank hub off w/out air tools? My friend says i wont be able to, and he says if its possible he says it will be extremely hard....
Let me know please
Thx
Old Apr 1, 2004 | 05:11 PM
Dave88LX's Avatar
I got mine off fine.
Just thread your balancer (Damper) bolt in a couple threads to use to push against with a puller.
joeSS97's Avatar
Yes,it is possible.Thats how I did it.
Old Apr 1, 2004 | 05:25 PM
I would bet that 90% of the people around here that have taken theirs off, have not used air tools. Don't know what your friend is talking about.
Old Apr 1, 2004 | 05:40 PM
Bryan 94 Z28's Avatar
Do a search, there have been plenty of threads lately on this topic. Plenty of good suggestions on how to get it off quickly and easily WITHOUT air tools (or torches).
Old Apr 9, 2004 | 02:27 AM
blown383's Avatar
How are you guys preventing the crank from rotating while pulling off the crank?
-B
Old Apr 9, 2004 | 03:00 AM
97WS6SCharged's Avatar
If it's a stick car you can put it into a high gear like 4th. That's what I did. I guess you're SOL if you've got an auto, but that's just one more reason why manual cars rock!
Old Apr 9, 2004 | 06:53 AM
RE AND CHERYL's Avatar
Cool
Are you talking about getting the bolt out of the balancer or removing the pressed on balancer. The bolt is a bit tight and is much easier with an impact, but you can wrap the belt around it to hold it still or remove the main pulley and use channel locks to hold it still.
When using a balancer puller you want to use a wrench or ratchet to press it off. Power tools will tear the puller up. OH...If you don't have a puller you can rent one from Auto zone for free. Gotta love that.
Old Apr 9, 2004 | 03:22 PM
FireAm94's Avatar
They make a tool to hold the flywheel/flexplate still.....or you can use a big ole flathead on the flexplate.
Joe
Old Apr 9, 2004 | 03:27 PM
ibanez6rg's Avatar
-B
I jammed a bar inbetween the puller and used force on that while using the puller. Didn't turn and worked fine.
Old Apr 9, 2004 | 03:51 PM
SweetZRag's Avatar
Use a 6 inch C clamp and put one end between the spokes of the hub and hook the other end under the torsion bar that runs directly under the pulley. You don't even have to tighten it. It works great and you don't have to hold it while working on the balancer bolts.
Old Apr 9, 2004 | 03:54 PM
scoobysnax83's Avatar
I have the ability to use air tools, but opted not to because I was afraid that I would break something. Is it ok to use em, or have people broken something using them in that area? Just doesn't seem good to use a jackhammer on your bottom end, lol
Old Apr 9, 2004 | 05:45 PM
blown383's Avatar
I ended up putting the car in 1st gear and was able to get the hub off pretty easily...I don't understand how people are having such a hard time removing it. But then again I'm using the Kent Moore tool.
-B
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
95chwagon
Jan 13, 2015 09:19 PM
