possible to change cam bearings with motor still in car
Old Feb 4, 2005 | 08:57 AM
hawk232's Avatar
is it possible to change the cam bearings with the motor in the car? i did a search and only found two people commenting on the matter, one said it cant be done, the other said that 4 out of 5 can be changed. assuming you could do 4 out of 5, would it be worth it considering that one of them would still be old?
Old Feb 4, 2005 | 09:05 AM
blackztpi's Avatar
Re: possible to change cam bearings with motor still in car
yes...have fun.. lol
Old Feb 4, 2005 | 09:16 AM
NOMAD's Avatar
It can be done on about the first 3-4. You have to have the engine out of the car and everything off the back to be able to get to the rear cam bearing. Most of the time they will fall down, which means your going to be pulling the pan too.
Better to do it right. Trying to change them in the car will be much harder than pulling the engine to do it. And your not going to get to the main rear one, so whats the point?
-Shannon
Old Feb 4, 2005 | 09:40 AM
hawk232's Avatar
alright, that about answers my question, thanks. my motor only has 60k so im hoping they shouldnt be too bad, ill take a look at them (as best i can ) when i pull out the cam
Old Feb 5, 2005 | 02:49 PM
94GreenZ28's Avatar
I wouldn't even try doing the bearings with the engine in the car. I just installed new bearings in my block and I think it would be extremely hard to intall the bearings with the crank and rods in there. Plus, having the K member in the way would make it even harder. If your were gonna change the bearings I'd just drop the engine out. It only takes about 4 or 5 hours.
LeftoverChinese
Jan 14, 2024 03:03 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
