possible causes for hissing/pulsating noise under load?
Old Mar 3, 2003 | 11:16 PM
mineralwater's Avatar
Here are the symptoms:
When I'm cruising at 20-25mph in 4th gear, and I give it a good amount of throttle, the car just doesn't start to pick up until the rpms wind up. While the rpms are winding up, there is a loud "hissing/pulsating" noise that I hear - its a lot louder when I'm next to a wall since it reflects the sound back to me. And its definitley not normal. It only seems to hiss when there is a high load on the car at low rpms.
I know a CAI will make a "sucking" sound - but this is a much higher pitched hissing sound, and it slightly pulses with the exhaust.
Now, at first I thought this was an exhaust leak, maybe a leaking primary slip tube, but then I started thinking it might be a vaccum leak, or maybe even weak spark.
At upper rpms, the car feels pretty good - its just at the 1k-3k rpm range that the car seems gutless and doesn't accelerate well.
Its not a burnt plug wire either - the car rides pretty smooth, doesn't buck/shake.
If anyone has any ideas, or suggestions, anything would help out.
Thanks!
Old Mar 4, 2003 | 01:01 AM
ah, thanks killer jello. I guess I can rule out vaccum.
That leaves my suspects as exhaust leak or weak spark.
THe reason I think it might be weak spark was that when I burned my #8 plug wire, the exhaust was gurgly, and the engine sounded especially "chuggy", with the hissing all over the place.
I usually thought exhaust leaks were more "ticks" - but on my car, I can't hear any ticks or hisses at idle - the hissing only starts when I get on the gas and put a load on the car.. revving in neutral won't make it hiss either
Old Mar 4, 2003 | 12:46 PM
Dr.Mudge's Avatar
You say low end sucks a bit (I can hear it chug), and that low RPM high load it makes the noise the worst, maybe it is a vacuum leak. We can check that when we look at your MAP numbers, and you also said your intake is leaking, so a few things are going together that could point to vacuum leak.
Old Mar 4, 2003 | 05:04 PM
Zjoker's Avatar
Exclamation hissssssinnnnn
I had that problem once. All I did was tighten my 2 loose back sparkplugs
Old Mar 15, 2003 | 04:18 PM
Re: hissssssinnnnn
Zjoker - I think you hit the nail on the head here - I found a really loose (i could spin it with my fingers) spark plug on #8. However, I tightened it and after about 10 seconds, the hissing came back. I wonder if there's another loose plug, or the same plug just backed out..
thanks I'm heading down to the car now to tighten all my plugs.
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
rideordie
Sep 7, 2015 08:22 AM
