Is it possible for a bad flasher to cause the right side to work but not the left?
Old Apr 10, 2003 | 05:36 PM
KillerTA's Avatar
All my bulbs are good and I can't figure out why my left side wont blink. The tailights work but not the brake lights or turn signal on the left.
By the way, I do have sequential taillights and the connections seem to be good.
Old Apr 10, 2003 | 06:12 PM
'94 Bad A Z28's Avatar
The only reason for the signals to not blink on and F-Body is that one of the bulbs is blown... How do you know all of them are good?
Old Apr 10, 2003 | 06:17 PM
norcalstreet's Avatar
I agree with '94 Bad A Z28 that it most likely is a burnt bulb. If the turn signal light turns on and stays on without blinking the culprit is most likely a burnt bulb. Check your front lights as well. A burnt front light will prevent a rear blinker from blinking.
Old Apr 10, 2003 | 06:22 PM
z28Power's Avatar
I dunno, if the brake lights aren't working either, you may have a short/ground somewhere in your wiring. Before you look into that I would definitely still check for burnt bulb in one of your lights though.
Old Apr 11, 2003 | 01:41 AM
Fatdog's Avatar
Cool
Sockets here.For some reason the sockets bite the dust.Have replaced both front,and 2 rear.In the sockets,it seems the black wire(ground)doesn't work after a few years.You can get replacement sockets at Kragen auto parts,or even pep boys for about $6.00.The dealer wanted $55.for each socket.Hope this helps.
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
BOOGER
Jul 25, 2002 02:42 PM
