POS coolant crossover pipe behind heads (help shoebox)
Old May 2, 2004 | 11:49 PM
  #16
Spinner's Avatar
Originally posted by shoebox
Part numbers are on my page:
1993-1994 steam pipe behind heads, incl bolts, seals and hose to radiator
10108635
1995-1997 steam pipe behind heads, incl bolts and seals
12556260
15mm is the correct wrench size.
All the round seals come off, but can be sticky.
Do what you gotta do, now that you have the heads off.
Is there any difference, besides larger bolts, in the later steam pipes?
Old May 2, 2004 | 11:59 PM
  #17
Serene's Avatar
i just cut the stupid thing and bought a new one. MUCH EASIER then messing with it
Old May 3, 2004 | 02:19 AM
  #18
MyZb383's Avatar
Having dealt with getting these off recently, I had a thought.
There's no reason to take them off before removing the heads EXCEPT that GM made the whole thing one piece, meaning you would have to lift both heads at once. Not fun.
I think when you get the new one, I'd just cut it in half in the middle and throw a flange and male/female threaded coupling on it. Cost next to nothing, take 10 minutes (if that) and would make the whole thing a relative pleasure to deal with, going on or off. Put the steam fittings on each head, put the heads on and just join and tighten your flanged coupling.
The way it should have been made in the first place, though saving that $0.25 was huge to GM, I guess.
HectorM52
Jul 30, 2017 11:46 AM
mr28
Apr 20, 2016 05:44 PM
MadMav
Feb 6, 2015 11:02 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
mr28
Nov 23, 2014 11:11 AM
