Porting intake to 58MM and still using a 52MM TB ?
Old Feb 22, 2007 | 02:49 PM
rawbutt's Avatar
I'm getting ready to tear down for a piston problem and want to take advantage of the opportunity as much as I can for other things. If I port my intake to 58mm, can I continue to use my Edelbrock 52mm until I go bigger with heads/cam and have more of a need for a 58mm or is that a crazy idea?
Old Feb 22, 2007 | 03:26 PM
BUBBA's Avatar
yes.
Old Feb 22, 2007 | 06:05 PM
matLT1's Avatar
Our cars came from the factory with an intake bore that was larger than the throttle body diameter. I don't think it would hurt you to take advantage of the oppurtnity.
Old Feb 22, 2007 | 08:05 PM
Z95m6's Avatar
I ported my intake while it was off knowing that in the future i would go 58mm tb. It worked fine until i got the TB.
Old Feb 23, 2007 | 07:15 AM
rawbutt's Avatar
Cool...thanks for all the comments. The only person that called me crazy was Bubba but he seems to be outnumbered
Old Feb 23, 2007 | 09:28 AM
BUBBA's Avatar
Your question was "can I continue..., and my response was "yes".
When you pose a question that has a conjunction in it giving the responder an option instead of just asking a question w/o options, you leave the responder with the option of answering all of the options----in this case, you ask "can I...." and then you end it with "or is that a crazy idea....?
In essense, my response, to wit: "Yes" actually could be my response to both the options, or "yes" you can do it and "yes" it is a crazy idea.
It was your assumption that my answer was "yes" to the option----it is a crazy idea.
Now do you think my response here was necessary or do you like girls?
Old Feb 23, 2007 | 04:03 PM
Brent94Z's Avatar
Super Moderator
You'll need to know what BRAND 58 throttle body you might go to. I have a 58mm AS&M TB and a Holley 58mm TB. With the Holley, the 58mm ports are "on center" in relation to the factory TB and exisiting 52mm holes in the intake. However, the AS&M 58mm TB had its holes drilled OFF CENTER as compared to the stocker. Just something to consider.
bubba, you're deep man.
Old Feb 23, 2007 | 09:05 PM
rawbutt's Avatar
Bubba,
Well said....and you are absolutely correct!
Noenav
Mar 1, 2019 07:38 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rje
Sep 9, 2002 12:35 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
