Porting intake for 58mm
Old Oct 14, 2005 | 10:36 PM
Heatmaker's Avatar
Advanced Member
Using a dremmel tool what is the best bit to buy to perform the job?
Old Oct 15, 2005 | 12:28 AM
Z95m6's Avatar
Re: Porting intake for 58mm
You might want to just look into having a shop do it. I spent $20-30 on a good bit for my drill and it took me a damn long time to do it. I'd much rather just pay $50 or something to a shop to have it done.
hallbilly's Avatar
ugg... another dremel... and a bunch of bits... or if you have a air compressor it should not be that bad. But if you are just cutting the front where the TB mounts... then a dremel and some of those round sanding wheels should be good... how many? I do not know. I would say 8 would be a good start. Most likely more....
Old Oct 15, 2005 | 07:01 AM
SnakeOiler's Avatar
Your best bet is to use a drill and 1.5" or 2" sanding drum. This will allow you to keep the holes in round and also speed up the process over using a dremel.
It's soft metal, sanding drum makes pretty quick work of it. I spent about an hour doing mine.
Old Oct 15, 2005 | 08:57 AM
OldSStroker's Avatar
A Bridgeport-type mill with a boring head does a great job. A good engne shop will have one.
Doing it by hand, I'd use the 1-1/2 inch sanding drum. Mark it careful and try to stay within the lines. Wear a dust mask or respirator.
Noenav
Mar 1, 2019 07:38 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
LT14LIFE
Feb 9, 2015 09:35 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
