Ported heads with cc503???
Old Jul 29, 2007 | 09:14 AM
chevyowner02's Avatar
I can't deside on getting my heads ported with this cam. There is a local shop that got 364hp and the guy was running the HC. I'm thinking if get them ported I'll want a bigger cam. But I have seen cars running 12-11's on stock heads.
Old Jul 29, 2007 | 01:17 PM
seawolf06's Avatar
No two cars will get the same hp numbers. You can get good times with a totally stock motor. What I'm saying is that you need to decide what your goals are. Low times, or high hp. Of course you "should" be faster with ported heads anyway as they are a huge restriction on these motors. If you trust the guy to do you right and you have the money, then get them done. Or you could just do the cam, see if that's enough, and then get the heads ported later.
Old Jul 29, 2007 | 01:48 PM
2000GTP's Avatar
What are your goals for the car?
Old Jul 29, 2007 | 02:00 PM
Thats kinda what I had in mind for now to see if the cam is enuff.
2000GTP, My goal is to get the car anywhere from mid 12's - high 11's as of now its going to be a full bolt on with the 503.In a 91 RS
Old Jul 29, 2007 | 02:06 PM
seawolf06's Avatar
The 3rd gens are lighter, IIRC, so with the right suspension, you should be close to your goal with that cam. If not, there's always nitrous...
Old Jul 29, 2007 | 04:35 PM
Yea I think they are a little lighter I have already done most of suspension mods.
Old Jul 29, 2007 | 04:48 PM
reamo04's Avatar
thats good, get some gears and you'll be high 11's with drag radials, people have gone low 12's with bolt ons, gears, drag radials, some suspension, and a stall (if a4)
Old Jul 29, 2007 | 06:44 PM
2000GTP's Avatar
A cam only car with all the correct supporting mods should easily get you in the mid 12s.
Old Jul 29, 2007 | 07:25 PM
CamaroSS30thAnn's Avatar
that cam should put u in the mid to low 12s with heads. The only way u willl hit 11s is if your car hooks like a mother.......and your suspension is tuned correctly. Also launching rpms etc
Old Jul 29, 2007 | 08:16 PM
Stl94LT1's Avatar
Personally, if finances allowed. I would port the heads no matter what aftermarket camshaft I was going to run.
Old Jul 29, 2007 | 08:21 PM
seawolf06's Avatar
Agreed. Furthermore, some head porters can actually do more harm than good if they really don't know what they're doing. You definitely get what you pay for in this area of modification.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Wilson
Jul 21, 2002 05:08 PM
