port quest.
Old Apr 24, 2003 | 08:36 AM
oldBones's Avatar
port quest.
Is a 22,000rpm die grinder too fast for working on cylinder heads?
Old Apr 24, 2003 | 09:29 AM
carnutz's Avatar
No, most cutting porting bits are rated at 25,000.
Old Apr 24, 2003 | 09:43 AM
oldBones's Avatar
Ok, thank carnutz I just wanted to double check because I had read that the ginder needs to oporate around 10000-12000 for cylinder head work.
Old Apr 24, 2003 | 10:52 AM
Mr. Z28 73/97's Avatar
Thumbs up
I tried one of the 22,000 rpm rotory grinders that Sears sells and tried to do some port work on Aluminum LT1 heads but the bit was moving so fast that as soon as it touched the head it was jumping all around the port. Almost ruined the head, I then logged onto the net and did a search for electric diegrinders and came across a company called Sunner where I purchased a variable speed electric grinder 4000 - 9000 rpms and have sucessfully ported several heads and intakes. I fell this is much better for a novice or first time head porter, because you can start off slow to match your opening and start your port shape then speed it up for mass metal removal with CONTROL.
Old Apr 24, 2003 | 11:47 AM
NOMAD's Avatar
Cool
It's better to start off a little slow since your working on aluminum heads, it will cut right through. Steel heads is a lil different.
You could buy a controller i'm sure to limit the rpms on the piece you already bought.
-Shannon
G-BODYT56
Jan 14, 2022 11:14 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
bunker
Aug 31, 2015 01:46 PM
bunker
Aug 1, 2015 09:47 PM
