Popping/Backfire?
Old Mar 24, 2004 | 09:08 AM
1FstFormulaV8's Avatar
Popping/Backfire?
I have a slight miss. I believe I have a messed bad plug. It seems to be on the drivers side. Whenever I'm under load in a high gear sometimes I get this loud pop/cracking noise from the driver side of the car. Am I having a bad miss fire there? Or perhaps wires?
Old Mar 24, 2004 | 10:40 AM
mike 96 ws6's Avatar
Re: Popping/Backfire?
could be or have you gotten your distributor wet lately? maybe hit a big water hole or a leaking water pump or washed your motor?
Old Mar 24, 2004 | 10:43 AM
Red96Lt1's Avatar
Have you checked your plug wires and all the obvious stuff?
Old Mar 24, 2004 | 11:34 AM
jdizzell's Avatar
You have bad wires, plugs or both.
Old Mar 24, 2004 | 07:52 PM
I has to be my plugs. It' take sooooooo long for the car to start now. I just got a new opti put in yesterday. The hesitation is much worse not then earlier. NGK's? Which do I need?
I took it over to the shop. I have a plug wire that is rubbing the pulley and belt. I assume it's arcing really bad. I think I have 2 or more that at like this.
Old Mar 25, 2004 | 08:33 PM
I tried rerouting the wires. It just made my miss worse.
z28beast
Oct 18, 2010 08:46 PM
lt1street
Jul 27, 2008 12:55 PM
