View Poll Results: Moser 12 Bolt or TH 400
Moser 12 Bolt
13
92.86%
TH 400
0%
Neither, save money for something else
7.14%
Voters: 14. You may not vote on this poll
POLL! Mixed thoughts, TH 400 or Moser 12 Bolt?
I have had mixed opinions on swapping for the TH 400 so I have decided I am going to do either one of these... Since I can do both for just about the same money, let me know what you guys think.
If you like the manual, get a nice aftermarket clutch like a street twin.
If you like the auto, which will be faster, get it and a stall (not sure what all goodies autos need).
Either way you are going to need a 12bolt and aftermarket driveshaft if you plan on going fast consistantly and reliably.
the T56 actually has a chance at surviving behind your combo. I had a built 4l60e that went through some abuse,somewhere around 475 rwhp and upwards of 600ft-lbs with nitrous. the output shaft broke after 2 years of abuse and spraying through shifts.
I would suggest the 12 bolt or a 9". the 6 speed really abuses the drivetrain behind it,and i have seen 12 bolts come apart at the end of high powered manual trans racers. The 9" is much harder to break,and some may cry about giving up the 3% loss due to the design,but you'll never look back if you get it. I went right for the 9",been 3 years and no regrets.
From: Albuquerque,NM--5,600 feet above you sea-level cats
Go for the rear end upgrade. That's the first thing I did when I built the new combe in sig. My last motor was a 383 on Nitrous. Blew the rear end up over ten times. Enough to buy a new one anyways.
Neal
Neal
I have a th400/3800stall with a 10 bolt behind it.. I'll find out if the 10 bolt will last on slicks at the track very soon.
...but I went with the 400 because my 4l60 was toast.
I'd go with the 12 bolt first and if the t56 gives you trouble later pull it out for a 400.
...but I went with the 400 because my 4l60 was toast. I'd go with the 12 bolt first and if the t56 gives you trouble later pull it out for a 400.
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
