Polishing Heads
Old May 19, 2006 | 06:47 PM
1LESSZ28's Avatar
Polishing Heads
Any gain to polishing them or roughining up the ports? I have heard many who say rough is better and others who say polished is the way to go???
(don't have the money to get them ported but have them off do to replacing head gasket so I wanted to try to improve a little.)
Also I think I am going to polish the combustion chambers to reduce carbon buildup and detonation. Any advice or tips? Thanks!
Old May 19, 2006 | 06:48 PM
Sparkz28ss's Avatar
Re: Polishing Heads
NA or boosted?
Old May 19, 2006 | 07:25 PM
1LESSZ28's Avatar
Re: Polishing Heads
Na .. ..
Old May 20, 2006 | 08:58 AM
526 SS 96's Avatar
Re: Polishing Heads
Just leave it alone. Save your money untill you can do something fun. I tried to "home port" a set of heads (gasket match actually) when I had my hot cam, and gained nothing (dyno tested). Just a big waste of time, but I was supprised at the amount of material I removed . Lastly, in my attempt to 'save money' I ended up messing up the casting so bad I had to buy new ones when the time came to have them professionally ported. The car never had a problem running, but my head porter could not undo the wrong I did.
Old May 20, 2006 | 06:25 PM
1LESSZ28's Avatar
Re: Polishing Heads
Not going to do any "home porting". thats not what I meant. I know many people that regretted ruining a good set of heads and most lost power. I was just going to lightly sand/ clean casting slag/ and polish the combustion chambers to a mirror finish to prevent detonation as I will be running a high DCR. Just wondering what finish the ports like (rough or smooth)?
Dmonty
Jun 2, 2015 11:19 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
thenewkid
Nov 27, 2014 09:41 AM
