plugs, wires, and coil?? real difference?
Old May 27, 2004 | 12:14 PM
allenk's Avatar
what kind of hp difference will i find?? and what type of each should I buy for a stock engine that will be modified shortly??
Old May 27, 2004 | 12:20 PM
SLeeper94Z's Avatar
If any of those are bad u will feel a difference but if there in working order you will not feel any difference
Old May 27, 2004 | 12:37 PM
krispy's Avatar
the stock coil is good, plugs and wires should be changed every 60k or so
if you are going to go the nitrous route you will want to go with non-platinum spark plugs with a colder range then stock (correct me if I'm wrong) and some choose to go with aftermarket ignition as well then
Fatdog2
Feb 13, 2015 08:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jazsun
Dec 29, 2014 12:14 PM
Ari G
Dec 11, 2014 03:21 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
