Plugs and wires
Old Oct 29, 2006 | 01:55 AM
ROUDA's Avatar
Plugs and wires
Ok I need to now how you change the plugs and wires on a 1995 LT1 camaro.
I dont want to drop the motor what do you do can you tell me how to change them. Thanks
Old Oct 29, 2006 | 01:06 AM
Lees94Formula's Avatar
You need a spark plug socket cut in half and a stubby open end wrench to turn the hex end of the socket. I think you can buy a shortened spark plug socket from one of the supporting vendors if you want. Definitely a set of ramps and some patience. Its not a quick job if you have the stock manifolds. Some people remove the alternator for better access. Expect it to take a full day being its your first time. Some are better reached from the top, some from the bottom. Just take your time and dont strip any threads and use dielectric grease, and gap the new plugs to spec.
Old Oct 29, 2006 | 01:43 AM
oneslowz28's Avatar
Use anti sease too. or the next plug change will be a pain in the ***
Old Oct 29, 2006 | 02:19 AM
ROUDA's Avatar
Ok thanks. I just swaped the LT1 in my 95 3.4 V6 camaro. The LT1 has 54k miles on it and I didnt think that the plugs and wires would need changed so I didnt do it now I have it all put togher and it runs like ****. Its not changing gears right either/ its an automatic trans, changed filter and fluid. It starts up ok but has no power and is running realy rough. It changes gears at like 3500 rpms into second gear. Im sick from the money and all the work I did. I stripped the wrecked camaro I bought and stripped my camaro bought all parts as needed all in 7 days. If anyone has any helpful info please let me know thanks.
Old Oct 29, 2006 | 07:30 AM
Bawls's Avatar
Are you running stock manifolds on the Lt1? if so I would swap with some pacesetter longtubes first before doing the plugs. lol.
No but really, just take your time, I was able to get all 8 from the top with stock manifolds and my fatass hands, holding nothing but a sparkplug socket and wrench.
Old Oct 29, 2006 | 08:52 AM
ROUDA's Avatar
What does it act like if theres a bad opti
Old Oct 29, 2006 | 08:55 AM
ROUDA's Avatar
What does it do if you have a bad opti.
Old Oct 29, 2006 | 01:07 PM
Bawls's Avatar
sluggish in low rpm, backfires, horrible gas mileage.
Old Oct 29, 2006 | 06:50 PM
ROUDA's Avatar
NOT BAD GAS MILEGE NO POWER AND RUNS ROUGH WHEN IN GEAR.
the car is not responceive at all hardly no power. you cant even brake stand it to burn tire theres no power. Runs ok in park but when its in gear it gets real rough. Does anyone have any ideas of what is causeing this problem. Could it be a opti or plugs and wires.
Old Oct 29, 2006 | 07:07 PM
Bawls's Avatar
The thing I'd do if you havent already replaced the plugs and wires, is start there. Their cheap. Then go from there.
Old Oct 29, 2006 | 08:18 PM
z95lt1's Avatar
plugs took me about 3hours. the drivers side wires are not to bad it is the passager side that is a pain in the butt the passager side alone took me 3 hours. most of the plugs i was able to get from up top the last one on the passager side is the hardest one (oil dip stick is in the way).
Old Oct 29, 2006 | 09:21 PM
ROUDA's Avatar
what kind of socet did you use cause some one told me to cut the spark plug socket in half and use a wrench to unscew the plug for easier clearence.
Old Oct 30, 2006 | 06:21 AM
Bawls's Avatar
i used a regular old plug socket with an extension and a universal.
Old Oct 30, 2006 | 10:37 AM
SMW's Avatar
SMW
Snap-on sells a nice spark plug socket with a built in swivel you can order on-line for roughly $20. It also has a two built in o-rings that prevent the insulator from snapping. Worked great....
Old Oct 30, 2006 | 12:36 PM
Beninarkansas's Avatar
Check EGR. Pull vac hose and plug it. See if it makes a difference. It curred my car. It's FREE!
