plug wirs with as&m headers
Old Apr 19, 2005 | 08:16 AM
steve40's Avatar
i'm in the middle of doing a heads/cam swap. when i originally installed the headers i had the lt1 f-body set of msd wires and had to make my own #8 cause the wire was too short and burned on the header.
i would still like to run the wires in the stock location, well atleast below the header. i heard that the msd set for the vette is longer, does anyone know if these fit? or any other wire sets out there that are longer?
thanks in advance
Old Apr 19, 2005 | 08:50 AM
Kevin_G's Avatar
Re: plug wirs with as&m headers
I am not sure about how long you want them but I used Moroso plug wires and they were great quality. I used them with AS@M headers. I also bought some heat resistant plug wire sleeves.. The worked great. I ran the wires in the stock locations. Since the wires are thicker than stock, it is a little tricky at the connector near the PS pump. Iused a zip tie to hold them in place
Old Apr 19, 2005 | 09:24 AM
OBE1 95Z28's Avatar
Accel 9000 wires stand up great against heat and are 8mm so they fit in the stock holders easier than the 8.5mm MSDs.
Old Apr 19, 2005 | 11:55 AM
Z28SORR's Avatar
MSD also makes a longer "cut to length" set. I saw a new product that advertizes being ceramic in the last Car Craft. Sorry don't remember what brand.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
racecarz28
Mar 30, 2015 09:55 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Skull Leader
Aug 10, 2002 11:01 AM
