Which plug wires with SLP headers?
Old Mar 12, 2007 | 09:00 PM
Camarocracy's Avatar
Going to install a set of 96-97 style SLP mids and I'm wondering which plug wires to use? The way the headers are shaped, looks like the stock routing would work best.
Do 8mm wires fit in the stock wire looms, or would I have to buy a set of universal SBC wire looms?
Anyone that has SLP headers have any input?
Old Mar 12, 2007 | 09:07 PM
2000GTP's Avatar
The 8mm wires will fit the stock looms. Taylor makes a good wire set in the 8mm sizing.
Old Mar 12, 2007 | 09:10 PM
SevenStars's Avatar
I'm using taylor's cut to fit wires set up on the side of the valve covers for my slp mids...
Old Mar 12, 2007 | 09:25 PM
96azhawk's Avatar
That setup will NOT work with the 96-97 style shortys though.
Old Mar 12, 2007 | 09:26 PM
96azhawk's Avatar
I had a hard time getting the MSD 8mm wires fitting in the stock looms that went around the alternator bracket, but still ran them in the stock location (under the headers) and made sure to use fiberglass sleeves when they were too close to the headers or block. I did not see that it would look very clean running them over the valve covers because you would need to heat shield most of them. That would be hard to make it look clean in such open view.
Old Mar 13, 2007 | 02:36 AM
Z95m6's Avatar
I believe the MSD's are all 8.5mm's. I know its only an extra .5 millimeter but it really makes a difference trying to fit them into looms.
Old Mar 13, 2007 | 09:36 AM
BUBBA's Avatar
I'd suggest sticking with stockers unless someone can show me the advantage of going with bigger ones. Keeping wires and hoses away from headers is important. I see no reason to make it more difficult by using larger wires or different routing unless you gain significant benefits by doing so.
If you want better fire, get yourself an MSD ignigition. JMHO
Old Mar 13, 2007 | 09:39 AM
2000GTP's Avatar
Yes, the MSDs are indeed a hair wider making them more difficult to fit those looms.
Old Mar 13, 2007 | 11:45 AM
afr lt1's Avatar
I have been using the stock wires with my set up, routing them as close to stock as possible. At a couple areas I wire tie the them loosely so they do not fall onto the header.
Old Mar 13, 2007 | 03:29 PM
Dave1980's Avatar
I am using taylor 10MM race with my shorties
Old Mar 13, 2007 | 09:45 PM
96azhawk's Avatar
Ahhh yes, that is true... I did forget about the extra .5mm.
Old Mar 13, 2007 | 09:46 PM
96azhawk's Avatar
Just to clarify, the setup I said would not work was referring to the valve cover side mount looms, not the wire size.
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
jim88iroc305
Aug 13, 2002 09:24 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
