Plug wires mounted on valve covers
Old Jul 28, 2008 | 03:04 PM
Mtxz453's Avatar
I did a search but could not find anything, maybe typing it in worng. Anyway.. I want to mount my wires on the valve covers like i've seen on a lot of others. Do they mak a special kit for this or do people generally drill and custom mount them on their own? Can I use the same Delco wires or do I have to get some sort of longer ones?
Old Jul 28, 2008 | 03:17 PM
'94 Bad A Z28's Avatar
OTVC kit.
Over The Valve Cover
Old Jul 28, 2008 | 03:22 PM
Mtxz453's Avatar
ahh thank you
Old Jul 28, 2008 | 03:39 PM
The_Bishop's Avatar
Do not buy the kit with the taylor wires in it! The taylor wires are junk. The looms for the valve covers are available on Summitracing.com, and use some quality MSD wires.
Old Jul 28, 2008 | 04:55 PM
AdsoYo's Avatar
There's a brand called "Made for You" that sells an 8mm OTVC set on summit which will fit the Taylor wires but if you go with MSD (which sells an OTVC wire set with LT1 specific boots) you'll have to drill the holes for that extra 0.5 mm. IMO the MSD's are worth it.
Old Jul 28, 2008 | 05:03 PM
Green96Z's Avatar
You don't have to drill the brackets out, the MSD wires fit just fine.
Old Jul 28, 2008 | 05:06 PM
83tpi_3rd-gen(sri)'s Avatar
i had taylor on my car and i never had any problems with them.
Old Jul 28, 2008 | 05:17 PM
derrickgott007's Avatar
How would I run thison my 97Z28 if my car has Smog setups on it? Wouldn't my wires burn when going down between the headers?
Old Jul 28, 2008 | 05:46 PM
Mtxz453's Avatar
anyone have the link to that MSD kit on summit? I can't find it..
Old Jul 28, 2008 | 07:02 PM
MarcR94v6's Avatar
I don't think the brackets are all that necessary, I didn't use them, just separators and zip ties.
Old Jul 28, 2008 | 08:04 PM
The_Bishop's Avatar
You can't do OTVC wires with stock manifolds. Headers only.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
