Plug wire changing
Old Jun 29, 2003 | 07:36 PM
1msfyter's Avatar
Plug wire changing
Is it neccesary to re use the cheap wire loom that the original wires are run through? Or just go with out it. Im installing MSD 8.5
wires.
Old Jun 29, 2003 | 07:52 PM
CamZ2811's Avatar
bla!
I left out the loom when i did my wire install b/c the 8.5s are to big for the stock 1/4 inch loom. just make sure that your wires are clear of your manifolds.
Old Jun 29, 2003 | 08:01 PM
1msfyter's Avatar
Actually Im talking about the black loom the runs the entire length of the wires , I case its supposed to protect them.
Old Jun 29, 2003 | 08:21 PM
AENIMA95z28's Avatar
kinda off topic but are these MSD 8.5 wires worth the $
Old Jun 29, 2003 | 08:36 PM
CamZ2811's Avatar
No Loom!
Going with out loom is ok just make sure you are not touching anything that will damage you new wires!
Old Jun 29, 2003 | 08:40 PM
95Blackhawk's Avatar
Go over the top of your valve covers with a loom kit, much easier to work on.
Old Jul 11, 2003 | 02:11 PM
TDog's Avatar
Loom with 8.5mm MSD
Hi Guys...
Can you use the MADE FOR YOU wire loom (ususally for 7-9 mm wires) with the 9.5mm wires...
OR...should I get a different center bolt loom...got any suggestions ...
Thanks,
TDOG
Old Jul 11, 2003 | 08:44 PM
Bud M's Avatar
I didn't keep any of the stock looms except for the one right next to the opti on the passenger side (which I enlarged with my Dremel to fit 8.5 mm wires). I got a set of Moroso looms (same as MSD/M4U) made for 8.5 mm wires to keep them routed nicely.
Old Jul 11, 2003 | 09:20 PM
The convoluted tubing is a good idea to keep away any mechanical abrasions.
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jazsun
Dec 29, 2014 12:14 PM
