Pleease help with nitrous piston selection!!
Old Jun 12, 2005 | 10:54 PM
djm_e22's Avatar
Ok I am either going with a 355 or 383 with 5.7 inch rods for my nitrous engine. But I want to get my compression ratio in the 10's. I found je pistons heavy duty flat top with the 6 inch rod option only to put my compression ratio in the 11's and all the extreme duty inverted dome pistons bring the compression ratio all the way down in the 9's. Does anyone know of a good nitrous piston of any brand where I can get my compression ratio in the 10's with a 5.7 inch rod? I plan on putting a 250 shot of nitrous on top of a LLoyd Elliot LE2 or LE3 package. Thanks for any help.
Old Jun 12, 2005 | 11:16 PM
Re: Pleease help with nitrous piston selection!!
BME will make you a killer custom nitrous piston in any configuration you want, for little more than a cost of off-the-shelf pistons. I'm running a 381, 5.85" rods, BME "nitrous" pistons, 10.8:1, and a 300-shot on top of a mild 500 (flywheel) HP street/emissions setup.
95blkss
Sep 22, 2015 03:18 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
CARiD
Sep 7, 2015 08:21 AM
