Please list all items needed for a cam swap...
Old Mar 9, 2003 | 07:30 AM
ucrazymonkey's Avatar
Just about ready to order what ever I need to do a full cam swap. Could someone list all what is needed before I order...
XE 230/236 on a 112 LSA cam
Cloyes Double Roller Timing Chain
I know I need some new lifters but could someone recommend some that ARE in stock and not going to kill my $550 budget.
Will I need to swap to a 95 Timing Chain cover when doing the cam install? I already have the Mezeire W.P. on the car. YOu can click on my web page to get any details about my car you may need.
Old Mar 9, 2003 | 08:05 AM
XE 230/236 112 LSA cam $239.95
Cloyes Double Roller Timing Chain $22
I can get a set of GM Lifters for $89.95 or Comp Cam for $239.00 and still will be under budget. What else is needed, besides gaskets?
Old Mar 9, 2003 | 08:21 AM
Is that timing chain only? You must have the whole set w/gears. You wil need a valve spring set, seals and the tools to put them on.
Where can you get GM lifters that cheap? The improved lifter set that I have seen was about $175.
Old Mar 9, 2003 | 08:34 AM
Through GM, employee discount.
I already have Crane 10308-1 Spring Retainer Kit on the heads that are on the car now. Along with Comp Cam Hardened 5/16 pushrods, ARP Head bolts, ARP Screw-in -Studs, Summit Guide Plates, 1.6 RR's with 7/16 stud and the Felpro Perframnce head gaskets.
You can get a Cloyes Double Roller cam for SBC for $20 through a source I wont say here on the board.
Im just trying to determine what is all needed to swap cams. Plus I already have LT1 Edit in the car.
Old Mar 9, 2003 | 08:46 AM
It would have been nice if you had listed all that you had in the first place. Then people would not have been wasting their time suggesting items that you already had. A search and some cam install websites should tell you all you need to know.
Old Mar 9, 2003 | 09:28 AM
Smokn '94 Z's Avatar
Lightbulb Re: Please list all items needed for a cam swap...
I don't understand why you would...
Old Mar 9, 2003 | 09:34 AM
Shoebox- All those items are plainly in my sig. I thought the purpose of a sig was to tell others what you have for mods. And if im not mistaken I believe we were suppose to keep it to 5 or less lines. My sig would have been 30 lines if I showed every little thing. That is why i created a web page. All you have to do is click on TA in my sig and it tells you everything I had. I thought I was just following the rules keeping my sig down and noe rambleing on like this in posts and threads
Old Mar 9, 2003 | 09:35 AM
joeSS97's Avatar
You should purchase a push rod length checker.You may need a new set of push rods.
Old Mar 9, 2003 | 09:43 AM
96ltz's Avatar
You can find everything here
I would check the part # on that timing chain too and make sure it's right
Dec 5, 2014 11:42 AM
Dec 4, 2014 11:56 AM
Dec 1, 2014 08:08 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
