Please help, smoke coming from exhaust!
Old Apr 18, 2004 | 07:58 PM
Z284LIFE's Avatar
Exclamation Please help, smoke coming from exhaust!
Ok here's the deal, all of a sudden my car started going through coolant like crazy, and today I noticed lots of white smoke coming from my exhaust....shortly after, the engine over-heated, so I pulled over to let it cool down. My car was in the shop a few days ago and the mechanic noticed a very small oil leak, and thought it was from the rear main seal, which I bet any money is actually the infamous intake manifold leak.
Would the intake manifold cause the symptoms I have? I can only drive my car like 5 min before it overheats, that's how fast it is burning up the coolant!
PLEASE HELP ME
Old Apr 18, 2004 | 08:06 PM
nateh's Avatar
Sounds an awful lot like a blown head gasket. White smoke in the exhaust and consuming coolant point to that conclusion. Take care of it quickly or you could damage the bottom end.
Old Apr 18, 2004 | 08:07 PM
CamaroSS30thAnn's Avatar
when my intake was bad i didnt blow smoke or loose antifreeze....and if it was a rear main sela i dont think that would happen either......u might have a blown head gasket.....not really sure but it would be good just to check
Old Apr 18, 2004 | 08:40 PM
iNF3RNo's Avatar
Stop driving it period.
Search about blown headgaskets. You'll get pointed in the right direction.
Old Apr 18, 2004 | 08:55 PM
SignatureSeries's Avatar
I agree...sounds like a blown head gasket...check into it quickly..you can ruin your car easily..
But then again..we may be wrong.
Old Apr 18, 2004 | 09:42 PM
Robs97Z28's Avatar
This is classic blown head gasket. It also could be a cracked head, but most likely head gasket. while the engine is idling check for bubbles in the radiator with pressure cap off. you should have a sweet smell from the exhaust. good luck
MattFick
Feb 15, 2015 10:16 PM
dale3in98
Feb 14, 2015 12:18 PM
MadMav
Feb 6, 2015 11:02 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
