please help with engine internals!
Old Jan 9, 2006 | 10:52 PM
T/A Racer's Avatar
okay so i spun a rod bearing and my crank and one rod are shot. so im looking to rebuild my engine on a budget. so i need atleast one rod, and a crank, piston rings, not to mention all the bearings and gaskets. while im replacing the crank id like to just upgrade to a 383 but im not sure on the price difference. where are the best places to get these items on a budget, does anyone have any of this stuff laying around they need to get rid off? help me out this is my only vehicle and i need to get it fixed on a pretty tight budget. thanks for your time, any advice is appreciated.
andrew
Old Jan 9, 2006 | 11:02 PM
hallbilly's Avatar
Re: please help with engine internals!
if you are looking for budget stay with the 3.48" crank
are you wanting to get more power out of it or just rebuild it? Or just fixe the broken parts?
Old Jan 9, 2006 | 11:13 PM
oneslowz28's Avatar
http://cgi.ebay.com/ebaymotors/COMPL...spagenameZWDVW
then look to http://www.eportworks.com for a head and cam package
then find some good 1.6:1 roller rockers
58 mm throttle body
then some larger injectors
then a walboro 255 fuel pump
500-800 in machine work
and a mail order tune from madz28 followed by some time spent tuning on the dyno.
all together around 4700 bucks and you will have a nice 383 but dont boost or spray it tomuch as the pistons in that kit arent forged.
now if you want a setup like i have then plan on spending 11-12k bucks. if you include the procharger
i would say stay stock and add a small sc like a powerdyne and save some $$$ to build the 383 the right way for when it blows.
Old Jan 10, 2006 | 09:45 AM
Z-RATED94's Avatar
Is it just me, or did someone not get the part where he said he's on a budget.
Old Jan 12, 2006 | 09:01 AM
T/A Racer's Avatar
Okay so basically im looking right now at replacing the one rod that spun the bearing, replacing rings and bearings, honing cylinder walls which are only 3 thousandths off factory spec, and replacing gaskets. i have to buy a crankshaft so basically i would like to know if its just plain stupid to go with a 383 crank with my factory pistons and rods? im not planning on spraying or boosting it just need to get it driveable. is this setup a reciepe for another blow up? also which is the weaker link between the factory rods or pistons?
Old Jan 12, 2006 | 09:03 AM
jsetzer's Avatar
Rods will let go first on the right tune (cap/bolts break). If your tune is bad, pinging will destroy the factory piston fast.
Nothing is ever as cheap as you hope. My 2k build has turned into $5500 and I haven't started assymbly yet.
Old Jan 12, 2006 | 09:28 AM
GetaZforgetGT's Avatar
383 crank (3.75 stroke) with factory rods will not work. The block has to be clearanced for the additional stroke. That is where the cost start to come in.
If I were you and really wanted to stay on budget, I would put a new crank in it and at least one new rod (rings and bearings obviously) and put it back together.
The word budget and stroker don't really go in the same sentence... As many have said here your budget is really just a guide because when you start to build it you start to put the whole project into perspective...saving $100 on this part then $50 on this part ends up not being a concern when longevity is your ultimate goal.
Old Jan 12, 2006 | 09:37 AM
Pullngz's Avatar
If you really are on a tight budget you could PM me, and ask about my stock crank that's just taking up space. I'm sure we could figure out how to get it to ya.
Mike
Old Jan 12, 2006 | 09:55 AM
T/A Racer's Avatar
i was confused about the block maching post. So could someone get by with machining the block for the longer stroke and using the factory rods or will the rods not work at all with a 3.75" stroke. also would different rods allow the block to not have to be machined?
Old Jan 12, 2006 | 01:35 PM
Demon's Camaro's Avatar
Depending on the damage that was done you may have to machine the block even if you want to stay stock.
What are your future plans?
That will determine what you should do. Since its dead now anyways just save up the money and do it right the first time. You will be much happier that you spent 5-8k once rather than rebuild it for like 3k and then rebuild it again because you want to forge the internals and run nos or a power adder.
If you can elaborate on your plans for the car people will have much more useful information. Budget and race car should not be used in the same sentence.
D1SC383LT4
Jan 26, 2015 01:41 PM
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Jan 4, 2015 08:43 AM
Jul 4, 2005 05:00 PM
