Please help do I need 02 sims for my exhaust?
Old Apr 26, 2005 | 04:51 AM
keng's Avatar
Hey guys I have a 97 Z28, I bought FLP long tubes and a loudmouth cat back.
The headers have the bunges for the o2 sensor, but do I need sims?
Old Apr 26, 2005 | 05:27 AM
slopokrodrigez's Avatar
Re: Please help do I need 02 sims for my exhaust?
Sims are needed only for the rear O2s and then only if the cats are damaged or removed. It prevents the PCM from kicking out a cat efficiency code. Sims are not used in the front O2 location since the PCM uses them for engine control.
Old Apr 30, 2005 | 02:35 AM
keng's Avatar
So how many 02 sensors are there.
The headers I have, have o2 bunges on heach header, can I put both o2 sensors one in each header?
Old Apr 30, 2005 | 03:45 AM
speed fiend's Avatar
You have four sensors, two of which will go into the bungs and two that go in after the cats. If you are removing your catalytic converters, you will need either O2 sims or have your rear sensors programed out of your pcm.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
May 15, 2015 10:43 AM
joffer00
Exhaust System
Dec 22, 2014 03:25 PM
timmat1
Jun 29, 2003 09:29 AM
