PLEASE HELP!! annoying vibration/sounds under the hood.
Old Sep 13, 2003 | 02:44 AM
JeremyKweens's Avatar
Ever since the nitrous install (1 week ago) I have this annoying noise from the engine bay. At idle, its a slight vibration/wooshing noise and if you rev it up it kinda increases with the RPM. In gear, it completely goes away while the engine is under hard acceleration but comes right back once you let off the gas or the clutch. When I am driving on the highway in cruise, the sounds turns more into a rattly vibration and stay constant.
now, the only things put on the car were the 2 selenoids, wires, braided lines, relay switch, and tapped into the fuel rail for fuel. All the nitrous lines are zip tied down so its probbably not the lines rubbing or anything.
This is really pissing me off and I would like to get it fixed!!!
Old Sep 13, 2003 | 05:04 AM
PoorMan's Avatar
The beginning of bearing failure?? Do a search. Never had one, but have seen others use those same words. Hope that's not it though
Jeff D.
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
cristian1311
Sep 12, 2015 08:16 PM
95mysticta
Aug 20, 2015 07:43 PM
Pestilence
3rd Gen / L98 Engine Tech
Aug 18, 2015 10:16 AM
