Please Help! ahhh no spark!!! What to check
Old Feb 2, 2006 | 05:47 PM
TRYTOTEST's Avatar
Just got done installing:
New starter
new battery
new headers
new y-pipe
New opti
new wires
new plugs
new msd coil
new msd 6btm box
new msd harness
and a supercharger
Now i get no spark........the engine just turns over thats it, dosent spark
WHAT SHOULD I CHECK!?????!
Old Feb 2, 2006 | 06:31 PM
Style's Avatar
Re: Please Help! ahhh no spark!!! What to check
Wow! You got alot of things you just added. Unfortunately, alot could do with spark. Do you sill have some of the old parts to swap in, such as the coil? Do you have voltage to the coil? It would be nice if you could bypass the MSD box to eliminate that possibility.
Old Feb 2, 2006 | 07:02 PM
TRYTOTEST's Avatar
I tried bypassing the box....still nothing
Also how do i check if im getting spark at the coil
Old Feb 2, 2006 | 08:28 PM
TRYTOTEST's Avatar
Ok i narrowed it down, I think its the ICM harness....I hooked up a mutimeter to it and im not getting any voltage at all.
How do i trace that back, also the fuse it good. Could it be a bad PCM?
Old Feb 2, 2006 | 08:51 PM
TRYTOTEST's Avatar
When i checked the voltage on the ICM connector, i heard a snap when i touched the leads to the connect. Like a fuse, but it was heard from the passenger side of the compartment...and the fuses are good
greenzee28
Mar 26, 2015 09:13 AM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
