please help....
Old Feb 7, 2006 | 09:43 PM
sweet93z's Avatar
please help....
motor is in and it doesnt run very good. I have a code. code 34(powertrain control module). what does this mean and what do i do to fix it because i have an LT4 hotcam and it sounds like i have a 306. i also got a tune from PCm forless for the cam.Im sure i have to adjust the rockers still, but why do i have this code? thanks.
Old Feb 7, 2006 | 11:35 PM
Re: please help....
DTC 34 = Manifold Absolute Pressure (MAP) sensor circuit (signal voltage low, high vacuum)
Check the connection to your MAP sensor.
Old Feb 8, 2006 | 07:37 AM
sweet93z's Avatar
Re: please help....
i dont understand why it would throw a PCM code... is their not a MAP sensor code? The car also bucks horribly until i clear 2000 Rpms, and when it gets warm it runs a little better.. Is that because of the map sensor
wildracer
Jul 30, 2010 12:49 PM
ttop1997
Jun 18, 2010 11:27 AM
AlwaysCode390
Oct 30, 2009 05:28 AM
sick9lt1
Aug 25, 2009 01:55 PM
1994TransAm
May 29, 2007 08:14 PM
