please help!
please help!
ok i have no clue what the problem is now. i keep getting code p0133. i replaced both o2 sensors after header install b/c they were bad. i recently replaced the drivers side header gasket and the code came back so i figured all the sealant burned off and fouled the sensor. so i replaced it. then about 3 weeks later i get the same damn code saying the sensor is slow. is the wiring bad or something because this is irritating and dont want to use 3 sensors in a month's time. any suggestions???? the d/s header doesn't leak either.
