please can some one give me some good info
Old Oct 6, 2008 | 09:43 PM
quickchek321's Avatar
i just did the valve adjusment again because my poly lock broke long story but anyway berfore i did the 2nd adjusment. The first adjusment; the car start and idle with a comp cam 306, 1.52 rocker arm stock injector and stock pcm. now when i start it wont go on. I went threw the wiring about 2 times. still nothing. i took my fuel rail off to see the injector spary but on 7 injector gas is coming out should all he injector spray. also have no 02 sensor on pacelong tube header with stock pcm. aslo when you do a valve adjusment before you crank it do you have to put at tdc
Old Oct 6, 2008 | 11:06 PM
Tex95Z's Avatar
First you really need to add a "signature" With your car info, year, mods stuff like that. It is really hard to understand your problem with everything jumbled together like that.
You should outline like this.
1. car not running.
2. What have you done
3. what are the symptoms
obviously you could outline it a bit differently but you get the idea. That will make it much easier to help you.
From the sound of it you have quite a few different issues.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Not Dave
Dec 11, 2014 06:32 PM
Queens94z28
Nov 20, 2014 06:03 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
