pitting in block surface ...what to do
Old May 8, 2008 | 07:10 PM
C5042081's Avatar
In the middle of doing a h&c swap
As i was cleaning off the head gasket i noticed pits around the front pass side around the water jacket hole. They are right in the path of the head gasket.
There not to deep but enought i can feel
I need some opinions here...what to do
Pull the motor and resurface the block or is there some sort of machining i can do with the engine in the car.
Or should i go with a new block?
Old May 8, 2008 | 07:45 PM
SS RRR's Avatar
Did it leak before? If not I wouldn't give it a second thought, throw the gasket on it and put the heads on.
Old May 8, 2008 | 08:09 PM
C5042081's Avatar
head gasket was leaking but not in that spot, I have everything pretty much off the motor, wouldn't be hard to yank it.
I would hate to go thru all the trouble of putting the new heads on and having them leak.
Old May 8, 2008 | 11:56 PM
SS RRR's Avatar
Not sure what kind of answer you're looking for then... If it wasn't leaking before, why would it start now? Unless you're going to use Cometics I would just leave it alone.
Old May 9, 2008 | 01:22 AM
FryedClutch's Avatar
if its gonna worry you pull it and get the block shaved a lil if you dont deem it necessary then throw it back together and have fun
plain and simple
Old May 9, 2008 | 11:21 AM
NJ-LE's Avatar
Smile
C5042081:
Why not just clean the pits and squeegee enough J-B Weld or some other epoxy to level the surface? (Just a thought)
Old May 9, 2008 | 12:16 PM
Dave1980's Avatar
Originally Posted by NJ-LE
C5042081:
that ran through my mind at first also, but what if he raised the portion too much? I think the gasket has enough in it to compress in and fill in crap like that.
Old May 9, 2008 | 12:24 PM
cnorton's Avatar
I think that if you position the head gasket on the block, you'll see that the pitted area is exposed to the coolant flow. The gasket doesn't cover it. I doubt that there is a significant level of risk of another leak at that point.
Old May 9, 2008 | 02:37 PM
C5042081's Avatar
The one pict i traced the gasket in red that run thru it just a little right on the border.
Old May 9, 2008 | 02:44 PM
ulakovic22's Avatar
I wouldn't worry about it, that's what the gasket is for.
Old May 9, 2008 | 02:50 PM
C5042081's Avatar
Just want to do it right, got a new set of LE2 heads coming and everything new on the top end
Old May 9, 2008 | 06:45 PM
SS RRR's Avatar
Seriously I like your style. This tells me you're going to pay attention to detail and not overlook anything. Those who ignore some things that may be important pay dearly later. However you will learn through experience that things like this will need to be ignored. To me, it's nothing more than imperfections that have been around for the last 50+ years. I think you should be good to go. As already mentioned a paper gasket aides in imperfections like what you've portrayed.
Good luck to you.
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
