piston to valve clearance in a stock lt1 bottom end
my friend just had a set of trickflow heads with a comp 306 cam & 1.6 rocker arms installed on the stock bottom end. he has not tried to start it yet, so i figured i would ask for him, does anyone know if there will be enough piston to valve clearance? i told him he has to be careful not to over rev it. thanks.
yes, they are 64cc's. no, he did not mill them, he was already concerned with clearance issues. i dont think he'll be down on power at all, considering the flow difference over the stock unported heads and the addition of a fairly large cam. would 10cc larger combustion chambers hurt that bad?
Low compression, too big a cam are not a good combination, especially when it is a cam well known for it's tendency to surge.
The 306 likes to rev a little beyond what is prudent for a stock shortblock.
All things I would worry about before I worried about PTV clearance.
Only "stock shortblock" LT1 I have heard of needing the pistons cut for valve clearance, was not so stock, I suspect it was decked, the heads milled and the cam was pretty nasty.
okay, i'll let him know he would he'd been much faster with stock unported heads. as long as the valves clear, he'll still be happy. thanks, i'll let you know if it sucks that bad, i'm kinda curious myself.
i rode in his car today. that setup may not be that great in an automatic car, but in a 6 speed with a 4.10 gear its pretty fast. it dont have as much bottom end as a expected, but it hauls *** from about 3000 and pulls very strong to 6500. we'll have to wait till spring untill the track opens to really see though but, i was not disappointed one bit.
the original post was about valve clearance. i appreciate the info telling me it would be fine, thats exactly what i wanted to know. i dont remember asking, or really care what everyones thoughts about the application or outcome are.
I have seen guys who thought they had fast cars run 16s at the track. M6 can add to the illusion due to hard shifts.
Rode in an f-body with a 306ish cam and 4.10s and it felt violent, but on the stip my ZZ4 cam/stall only Caprice was side by side with him.
