pin hole leaks... OMG
Old Apr 19, 2003 | 06:37 PM
anasazi's Avatar
to top off a new waterpump, now it looks like at least one, maybe two of my radiator hoses are LEAKING... pinhole sized leaks.
the first one comes off the top of the waterpump on the drivers side. it *looks* like a normal hose... is this correct? i can just get it from discount auto?
the second one comes off the passenger bottom, and its got some sort of in-line device on it and i don't know what it is. if i cut off the end of the hose so that the pinhole is cut out then it might be too short before it hits that in-line thing. i'm not sure where it goes to but it looks like it runs back to the firewall, possibly heater hose? whats the part number for this thing and how much does it cost? it looks like a real pain in the rear to replace...
also, are there any kits from GM that replace all the radiator hoses? i have a feeling that my 8 year old hoses are going to all start dumping on me pretty soon...
Old Apr 19, 2003 | 06:48 PM
Wild1's Avatar
Yes typically any hose will work. About the heater hose, they are crimped on and will only be replaceable with factory components. I've seen some guys actually saw off the crimping and get a standard heater hose with two hose clamps and tighten it directly on the steel pipe. It seems to be working for them.
Jason Cromer is a factory parts guy in Florida. I don't have his number but if you do a search, you'll find him.
Good luck.
Old Apr 19, 2003 | 07:10 PM
anasazi's Avatar
how do i replace that hose? it looks like its a real pain in the ***! whats the part number?
Old Apr 19, 2003 | 07:12 PM
Wild1's Avatar
I checked Shoebox's site and his link is down. Do a search for Shoebox and click on the link in his Signature. You'll find some good graphics which will help you. It isn't tough. I don't have the number on me but I'll push this to the top.
Old Apr 19, 2003 | 07:55 PM
Droff's Avatar
It sounds like your talking about the heater box hose. Yes it is a BIG PAIN!! The GM # is 10261147 It cost $60.16 from GMPartsDirect. Otherwise about $120.
Old Apr 19, 2003 | 08:28 PM
anasazi's Avatar
ok for 120 bucks i can deal without heat...
is there some way i can run the hose WITHOUT that in-line thing? whats that in-line thing do anyways?
Old Apr 19, 2003 | 08:38 PM
It's a flow restrictor. Not sure what will happen without it. Maybe nothing.
Old Apr 20, 2003 | 01:21 AM
Mtrhds94Z's Avatar
Do a search for 'goodyear hi miler hose' [in LT1 tech] and read the posts..
I put some good info in most of those, that will help you..
Old Apr 20, 2003 | 09:46 AM
anasazi's Avatar
here is the leak:
http://anasazi.sytes.net/waterleak/MVC-317S.JPG
would it be OK to just cut off about 1 - 2 inches of that hose and then just slip the remaining over the waterpump outlet?
Old Apr 20, 2003 | 10:37 AM
If the leak is far enough away from the restrictor, I would cut it where the hole was and put in a hose barb. Adjust or add length of hose as necessary to make it work.
Old Apr 20, 2003 | 11:27 AM
anasazi's Avatar
ahhh brilliant, i'll be doing that!
Old Apr 20, 2003 | 07:50 PM
Mtrhds94Z's Avatar
Or Dremel that crimp connector off [CAREFULLY]and then add a short[4" +- ]regular heater hose and regular clamps...
You can Dremel it off while on the car still..
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
drt
Sep 27, 2015 04:39 PM
frankrizz
Sep 23, 2015 04:21 PM
