pin on cam help!!IMPORTANT
Old Jan 27, 2003 | 01:14 AM
slashz28's Avatar
hi guys . k, i bought a used cam a few months ago and just got to comparing the dowel pin on it to my stock one, and its shorter so i guess its for 93-94 non vented cars i got a 95. what could i do? maybe take them to a garage , maybe they could swap the pins? a machine shop? help me out please, this just f**ked me over big time. thanks as always guys.
Old Jan 27, 2003 | 01:43 AM
94 CAMRO Z28's Avatar
Im not 100% sure on this but I would think any engine shop should be able to swap that pin for you pretty easily and cheap. I dont think its anything much to worry about.
Aaron
Old Jan 27, 2003 | 02:06 AM
Camaro37's Avatar
If you can't pull it out yourself (I couldn't) you could take it to a machine shop or find someone with a slide hammer. I took it to a local machine shop and they did it for free, takes maybe 5 mins. I tapped my other dowel in with a hammer and measured it closely.
The long dowel should extend .620" (a bit less than 5/8") from the end of the cam.
The short dowel should extend .300" (bit less than 5/16") from the end of the cam.
LeftoverChinese
Jan 14, 2024 03:03 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
sscott
Jan 17, 2015 04:30 PM
Red97LT1
Aug 15, 2002 08:33 AM
