Piece of the crank hub broke off!! HELP!
Old Apr 30, 2005 | 04:26 PM
Cmr0z28's Avatar
WTF! I am SO pissed right now.
I was taking off my crank pulley (installing electric water pump), and when I took the 2nd bolt out, a metal piece fell on my head. Turns out it's one of the 3 pieces that the crank pulley bolts to.
Can someone please explain to me the easiest possible way to replace it?
Old Apr 30, 2005 | 04:34 PM
Zachz28's Avatar
Re: Piece of the crank hub broke off!! HELP!
I feel you pain i was there a month ago during my cam install this is what i did. I got a sawzall blade for cast iron and i cut 3/4 of the way all around the hub and then beat it of. i then took the timing cover off and used a 3 jaw to pull the crank timming gear and the rest of the hub off. i was scary but i didnt damage the crank at all.
Old Apr 30, 2005 | 04:56 PM
Judge-Jury-Executioner's Avatar
From: Whinersville, USA formerly known as Philadelphia, PA
You can get a keyed hub from Thunderracing.com
Old Apr 30, 2005 | 10:07 PM
I think he wants help in removing the one he has on there now.
Old May 1, 2005 | 11:51 AM
Cmr0z28's Avatar
shoebox, am I going to be able to use a puller with only 2 ears left?
Old May 1, 2005 | 03:07 PM
BlackLT1_TX's Avatar
Why were you pulling the crank hub to put on a electric water pump? You might have to put some heat on the hub and try pulling it with only the two remaining ears. Make sure and be careful with the heat though, as you will probably ruin the front main seal (no biggie).
-James
Old May 1, 2005 | 03:42 PM
Beyonce Knowles's Avatar
-James
I believe you have to remove the front cover to plug the water pump driveshaft hole.
Old May 1, 2005 | 05:24 PM
dynomight's Avatar
i would say heating, beating, and lubing it up. i think patience is your best tool here. maybe a claw type?
gl
jb
Old May 1, 2005 | 05:28 PM
94zgreenmachine's Avatar
I would try to weld the tab back on and apply a little even heat to the hub and try pulling it off. Assuming you have access to a welder.
Old May 1, 2005 | 10:03 PM
Cmr0z28's Avatar
Old May 1, 2005 | 10:38 PM
I am surprised you did not crack the timing cover with that procedure. It must be stronger than I thought.
Old May 1, 2005 | 10:48 PM
Cmr0z28's Avatar
I kept an eye on it, but a wide socket was used so that the force was not concentrated on one small area.
Old May 2, 2005 | 11:28 AM
VintageMuscle's Avatar
I broke mine too because I did not recognize that the puller must push on the crank bolt threads...
I chose a more expensive but less time consuming path...
I took the timing cover loose, pulled it out over the crank hub which destroyed the seal, spun it upside down and cut a huge notch out of the cover to remove it. Next I used a large two prong puller and carefully pulled the crank gear and hub off together without damaging the crank bolt threads.
I did have to grind material off the puller legs to fit behind the crank gear, but it worked. Unfortunately, it seems like the cover and the hub cost me $150 or more....memory failing......need to drink more beer to kill off the weak brain cells....survival of the fittest!
Old May 2, 2005 | 02:45 PM
HBHRacing's Avatar
It's hard to tell from teh pic but you might have been able to use a normal 3 leg puller on the flats of the hub between the ears. I'm pretty suprised that the timing cover didn't crak as well. I would consider yourself pretty lucky.
Old May 2, 2005 | 03:12 PM
Cmr0z28's Avatar
There's barely anything to grab onto...it wouldn't have worked. I used the widest socket possible so that the force was not concentrated on one area.
