Pictures of my stock 100k mile oil pump
Old Dec 1, 2007 | 04:23 PM
speed_demon24's Avatar
I'm definatly glad I'm changing it. And the spring in it was weak as hell to, it wasn't even seating the bypass valve all the way shut against the side.
Old Dec 1, 2007 | 06:47 PM
bowtie buddy's Avatar
Thats a Motor waiting to blow!
Old Dec 1, 2007 | 06:59 PM
SStrokerAce's Avatar
Lotta junk got in that bottom end over time... i've seen seized up 200,000 mile truck motors with better looking pumps!
Old Dec 1, 2007 | 08:01 PM
texas94z's Avatar
whoaaa you just saved your self a big headache down the road. it makes me want to check mine with 138k.
Old Dec 1, 2007 | 10:06 PM
Yeah tell me about it. I'm guessing the oil filter caught all of the **** before it went through my motor since I don't see how it could still be running if it didn't.
Old Dec 1, 2007 | 11:19 PM
hotrod18_69's Avatar
Wow, thats pretty buggerd up. Lucky find...
Old Dec 1, 2007 | 11:36 PM
Z28_AJ's Avatar
where is the oil pump at on the motor
Old Dec 2, 2007 | 12:37 AM
Jazsun's Avatar
You gotta take your intake manifold off and you can access the drive I believe.
Old Dec 2, 2007 | 01:04 AM
WS6T3RROR's Avatar
Bolted to the rear main cap.
That oil pump looks like it had shrapnel run through it, guess thats what happens after half a dozen cam and head swaps though . Lucky the filter caught most of that garbage.
Old Dec 2, 2007 | 01:38 AM
marshall93z's Avatar
Damn, makes me wanna take apart my 267,000 mile one! That looks terrible!
Old Dec 2, 2007 | 06:29 AM
One of the lobes started coming apart on my gm846 about a year ago so I'm guessing thats where it came from. And this is only my 4th cam swap and 2nd head swap... well 3rd head swap this motor has seen if you count the heads that were on it when i bought it.
Old Dec 2, 2007 | 01:11 PM
WS6T3RROR's Avatar
Yeesh never seen a billet cam core fail without a lifter failing first. Got any pics of the lobe?
Old Dec 2, 2007 | 03:34 PM
No I never took any. There was some damage to the valve stem tip on it too so I think I was getting valve float, and the lifter roller was damaged just like the lobe was.
Old Dec 2, 2007 | 03:51 PM
What springs were you running?
Old Dec 2, 2007 | 04:44 PM
Z28LT1_Just_Nasty's Avatar
Thats the exact reason the first item of my winter build is a brand new oil pump and a white spring. Just received it this week as a matter of fact. That oil pump is beat to hell though.
