Pics of my true dual setup with convertible X brace
Here's some pics of my true dual setup. Consists of Kooks LTs, Dynatech 4.5x7" ovals, and 3" Pypes mini cats. I was hoping these Dynatechs were a little quieter than race bullets, they are straight thru split flows, and they sound great, not very loud at idle but really yell on heavy accelleration. Cats are 3" then it necks down to 2.5 the rest of the way back. I also custom made an X-brace to replace the factory stamped one that is on the convertibles, the pipe fit perfectly over it.
Sitting on trailer showing clearence from the rear
http://hometown.aol.com/onebadwskier...95taduals1.jpg
Lowest part on driver side cat, this could have been raised about a 1/2 inch and I will do it if it hits:
http://hometown.aol.com/onebadwskier...95taduals2.jpg
Passenger side cat has very good clearence
http://hometown.aol.com/onebadwskier...95taduals3.jpg
Pic of the muffs looking straight up from below
http://hometown.aol.com/onebadwskier...95taduals4.jpg
The entire setup from straight under
http://hometown.aol.com/onebadwskier...95taduals5.jpg
From the rear showing X-brace
http://hometown.aol.com/onebadwskier...95taduals6.jpg
The pipe snaked thru the X-brace
http://hometown.aol.com/onebadwskier...95taduals7.jpg
The X-pipe above the tunnel and X-brace and cats
http://hometown.aol.com/onebadwskier...95taduals8.jpg
The pipes coming over the axle
http://hometown.aol.com/onebadwskier...95taduals9.jpg
Closer pics of the mufflers and tips
http://hometown.aol.com/onebadwskier...5taduals10.jpg
Re: Pics of my true dual setup with convertible X brace
Looks nice but yuu might want to put some heat wrap around that bundle of steel lines. It's your brake and fuel lines and it looks like the pipe is like an inch from them.
Re'
Re'
On this picture is Panhard rod and another thing what goes from top end of panhard rod to body... How it called? Where i can bye it?
Thanks!
Thanks!
Re'
Re'
Thanks!
Thanks!
http://www.bmrfabrication.com/F-bodySuspension.htm
Panhard rod relocation kit.
Originally Posted by wrd1972
Are those vert specific SFC's. Where did you get them?
http://www.bmrfabrication.com/F-bodyChassis.htm
Look about half way down the page, they have them specific for the verts.
Originally Posted by dreamer1q
I wish I could find someone who did dumps before the axle with a Sphon TA on it and still a vert. Would love to see photos of that.
http://hometown.aol.com/onebadwskier...Xbraceside.jpg
2Quik6, you have any more photos of that. Thats exactly what I was looking for.
http://hometown.aol.com/onebadwskier...-underside.jpg
Here's a good one of it..also, notice where the ends of the X bolt to, I welded 2 tabs on the bottom side of the tranny mount to bolt it to..that way it brought the front of the X down a little more for clearence for the pipe to go over instead of bolting it to the top of the tranny mount.
http://hometown.aol.com/onebadwskier...racebottom.jpg
http://hometown.aol.com/onebadwskier...-torquearm.jpg
oh, it still had the stock exhaust on it in these pics though...
As you can see, all I did was weld some very thick flat stock I got from Home Depot onto the Spohn tunnel brace to make the "X"and also used a sledge to bend the center of the X down some for more clearence for the pipe to go over the brace and under the tranny tail shaft.
