In a pickle
Old Jul 1, 2005 | 10:42 PM
endobong's Avatar
In a pickle
Ive been reading up on alot of old post but just wanted some opinions... This morning I tried to start my car and it wouldnt fire just cranked and cranked.. So from there I check the spark of the coil and its good (brand new msd) then I check the spark from the spark plus and they are also sparking good... So good news its not the opti, So fuel right? I took off my nitrous fuel line and turned the key and no gas anywhere.. ussually it would poor out, Then I pulled my fuel filter and it wasnt clogged, also with it off I turned the ignition on again and still no gas, So im thinking fuel pump or maybe just a fuse??? Also can someone tell me where the fuel pump fuse is.
Old Jul 1, 2005 | 11:42 PM
JP94Z's Avatar
Re: In a pickle
Not sure what year you have, but my 1994 owners manual says there's a fuse leading to the fuel pump relay in the dash fuse box, #5 a 15amp.
Old Jul 2, 2005 | 12:03 AM
ibanez6rg's Avatar
Re: In a pickle
Can you hear the fuel pump prime while getting ready to start the car?
Old Jul 2, 2005 | 12:05 PM
endobong's Avatar
Re: In a pickle
thanks for the help guys you dont know how much i appreciate it, I went out and checked the relay and it clicks on... also if i prime it a few times.. like turn the key on and off 5 or 6 times my car will start but then die a second or two later... so.....??
Old Jul 2, 2005 | 03:41 PM
97zSC's Avatar
Re: In a pickle
http://www.taekwondoplus.org/z28/fuelpump.html
if you are gunan change the pump here is what some people prefer to do. personal preference on whether you want to drop the rear -end and all, or do some cutting :-)
Old Jul 2, 2005 | 06:21 PM
endobong's Avatar
Re: In a pickle
I just finished up cutting the hatch out, Went and bought a dremel and wow those things are great.. No I just have to wait till tuesday to get my new pump, btw heres a pic
http://memimage.cardomain.net/member...04_35_full.jpg
BIGRIG
Parts Wanted
Apr 28, 2015 07:56 AM
