View Poll Results: When choosing a camshaft, which philosophy do you go by?
"Go big or go home"
20
46.51%
As small as I can get away with
23
53.49%
Voters: 43. You may not vote on this poll
Which philosophy do you go by?
Old May 17, 2007 | 11:41 PM
  #16
Dan Parker '96's Avatar
Torque curve, gears and traction. The end is all math.
Old May 18, 2007 | 01:30 AM
  #17
firebird84's Avatar
i dont believe in either you need what is right for you car and setup...i wouldnt think like that
Old May 18, 2007 | 07:45 AM
  #18
stereomandan's Avatar
I tend to look at cams that most guys consider small. I don't consider it "as small as I can get away with". For me, it's actually as "big as I can get away with" and still have near stock driveability, good low end TQ (2000rpm+) and not have to spin to 6500-7000 to make it shine.
That puts me with cams like the GM 845(214/224 0.521/0.543), Hotcam, CC502, Crane 227, Lingenfelter 221....
Dan
Old May 18, 2007 | 09:28 AM
  #19
OldSStroker's Avatar
Originally Posted by rskrause
We are getting pretty metaphysical here! Kind of like the "Zen of the camshaft". You can't talk about the cam in isolation. As others have alluded to, you start with an idea of what you want - a goal. And you must have an awareness of limits - financial, time, physics. And you meld these together into a harmonious whole.
It's easier to work out a race cam than anything else because it's relatively easy to define the goal. In the case of drag racing, to get down the track as quickly as possible. Fuel economy, emissions, and that sort of thing are irrelevant. As long as you can drive through the pits, drivability is not important. But even with a simple goal, you immediately have to consider the system. What is the weight of the car, what tranny will you use, is it an 1/8 or a 1/4m car? What are the best heads you can afford? What fuel will you use? Carb or FI? Nitrous? A blower? And so on. Once these variables are defined, you can start to think about cam specs. In the end, the right choice is unlikely to be the biggest cam or the smallest one. It will be the right one.
Bret designed a cam for me a couple of years ago that was a masterful compromise. Useage was street and strip. The car has a blower and nitrous is used intermittently. The car has to run on 100 octane unleaded as cats and a full exhaust are used. That's a tough one!!! I bet he made lesss than minimum wage figuring that one out.
Rich
Bret's gotten much faster because minimum wage here in NY went up.
"Zen of the Camshaft" might be a good title for his first book.
Excellent post, Rich.
Old May 20, 2007 | 06:03 PM
  #20
sn8ke eatr's Avatar
pill it till ya kill it baby!
Old May 20, 2007 | 06:37 PM
  #21
jonesy's Avatar
put the best heads on money can buy and cam it accordingly
andy katzelis
Sep 1, 2008 07:05 PM
NewsBot
Jul 23, 2008 05:40 PM
