People that have done the opti conversion, how much did it cost?
Old Apr 9, 2003 | 02:34 AM
allmotorta's Avatar
I'm ordering these next week for my opti conversion, how much do they cost? I'm ordering them through Jason Cromer...
-95 Timing cover
-95 opti electric harness (12130319)
-opti vacuum harness (12555323)
-opti vacuum fitting (14082470)
I already have the opti and all other related stuff...
I don't want to bother Jason Cromer for price info, and I know a lot of you have purchased this stuff, so I figured I'd ask you first thanks!
Old Apr 9, 2003 | 11:39 AM
CARGASM's Avatar
he has a convrsion kit available, i think it is roughly $350
Old Apr 9, 2003 | 11:42 AM
chesee48's Avatar
Sorry this is off topic, but i thought i'd post here anyways...
This way it'll bring you to the top as well
I was wondering..I have a 94 LT1 and when i do my heads/cam swap i was planning on doing the 95+ opti conversion with the 95+ Timing chain set/cover...Now, i decided agaisnt the 95+ opti conversion b/c i bought the SDI Opti-delete, now my question is...Do i then need a 94 Timing chain set/cover then or will the 95+ timing chain set/cover work ok still?
Old Apr 9, 2003 | 10:37 PM
allmotorta's Avatar
anyone? I don't need a whole conversion, I already have the vented opti
Old Apr 10, 2003 | 06:43 AM
QUASARBLUEZ28's Avatar
Here is a list of parts I compiled when I did my conversion on my 94. Prices may have changed from a year or so ago.
Part Part # Price
Elec harness 123130319 $53.50
Vac harness 12555323 $11.15
Vac fitting 14082470 $2.10
OPTI (95 Vented) 1104032 $219
Timing Cover (95) 12552426 $45
Timing cover gaskets 10128293 $2.05
1LE drive shaft 10085375 $220
1LE Trans mount 22146231 $11.50
Intake Gaskets 12524653 $16.00
Water Pump Gaskets 10128343 $0.55
Rear Main Seal 10088158 $13.75
Valve Cover Gaskets 10046089 $18.00
Thermostat Gasket 12551507 $2.05
Serpintine Belt 12550149 $16.50
Coil 10477208 $28.00
Clutch Pilot Bearing 14061685 $7.10
LT4 Knock Module 16214681 $26.95
Old Apr 14, 2003 | 12:56 PM
allmotorta's Avatar
Part Part # Price
Thanks! exactly what I was looking for
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Z28Wilson
Aug 1, 2002 04:27 PM
